QtShanoir is a C++ Qt based library for querying data from a Shanoir server. For those who don't know what is shanoir, see the shanoir website.
QtShanoir uses the soap based webservices provided by a shanoir server to get and display studies, patients, data with their associated metadata.
In QtShanoir, you will find a set of Qt widgets (inherited from a QWidget object) that you can embed in your Qt application.
QtShanoir is licensed under the LGPL. You can get the latest code with git: git clone git://scm.gforge.inria.fr/qtshanoir/qtshanoir.git
This project is sponsored by the french institutions INRIA, the University of Rennes 1 and the CHU Pontchaillou hostpital. This project also takes part of the VisAGeS research team. Please contact Olivier Commowick for more information.
